- Thu Feb 21, 2013 2:58 pm
#365143
Hi there,
I wanted to create a multilight animation but it seems like Maxwell is always exporting the same frame without changing the light intensities.
for the test I setup a cube and 3 light emitters around, activated multilight, rendered the picture, stopped the render, then changed the multilight values at the beginning, the middle and the end. I made sure keyframe were created and when playing the animation it was shown in the small peview window.
Now i used the 'save sequence' from the multilight option toolbar and as many pictures were exported as I had frames arranged. During the export Maxwell went from one frame to the next, each time I could see the sliders in the multilight tab change accordingly but when checking the exported pictures ALL of them showed the very first frame - so each picture is the same.
What do I do wrong or what has to be changed to make it correct and export each picture with a different light setup as it should?
Cinema4D Studio MSA, MoI 14+1+1
- By Matteo Villa
