By w i l l
#364940
Does anyone know the solution to the problem of Textured decal shading that shows no decal and everything looking mostly black. It's nothing to do with clicking the button in the Material Editor to insert the texture into the scene.
By itsallgoode9
#365044
One thing to try, that is more of a work around, is opening a default scene the importing your scene that you've been having problems with. It probably won't work, but it's worth a try. Every once in a while that has worked for me when i run into weird problems.
Otherwise, I run into a similar issue when logging into my work computer remotely from my laptop, which is getting two/three years old at this point and has a sub par graphics card. Maybe a graphics card driver issue or an older graphics card?
Even though either suggestions may not work, it doesn't hurt to check it out.
