- Wed Jan 30, 2013 7:53 pm
#364632
I am having a problem with Sketchup Pro file saving once I run the Maxwell Ruby UI.
As an example, let's say I have a file open in Sketchup named Test.skp.
I have autosave set for 30 minutes in Sketchup.
I edit the file and autosaves are done.
I save the file and exit Sketchup, thus closing the maxwell UI.
Looking at the file directory, I have the following:
Test.skp
0.skb
1.skb
2.skb
3.skb, etc.
Each 30 minute autosave is incremental AND the last file is the last saved edit version of Test.skp.
If I open the Test.skp file, it will be the version I began with at the earliest date and time of the edit session.
I have tracked it down to the process named agcp.exe *32 placing a file lock on the original file, thus forcing Sketchup to incrementally save.
This appears to be from MS Silverlight.
I suspect each file increment is locked also, thus compounding the problem.
I have to close the agcp.exe *32 process in Task Manager before I can rename and change file names since they continue to remain locked.
I recently update the OS to Windows 7 Pro 64bit from 32bit. Could this be an issue?
Otherwise, I am at a loss as to how to remedy the problem.
Test.skp
0.skb
1.skb
2.skb
3.skb, etc.
- By Matteo Villa
