#362121
Maxwell for Cinema 4D
Version 2.7.22 Release Notes
Changes
  • Compatible with Maxwell Render 2.7.20.
  • Added R14-specific plugin build.
  • Added support for native Cinema particles.
  • Added support for 3D Realflow vector displacement type.
  • Improved behavior of pretesselated disp. in material editor.
  • Sun tag is now ignored if its Enabled checkbox is not checked.
  • Region tag may now be placed on Cameras or Scene Objects.
Fixes
  • Copy/paste path in texture editor no longer changes all paths.
  • Camera mblur was not exported unless object mblur was enabled.
  • Cinema lights in certain hierarchies could be exported twice.
  • Texture disable checkboxes were not working correctly.
Notes
  • Particle export uses a new Maxwell Particles tag, which is designed to be placed on Particle Emitter and Particle Geometry objects; you can export using spheres, or you can link to a polygon object, where each particle will be an instance of that object. For Particle Emitters, if they have geometry under them, they will be exported the same as before; to export using MaxwellParticles, a Particle Emitter should have no child geometry. You will find more detailed information on the new tag in the plugin manual.
