By arch3d
#358700
I found some new bugs in plugin:
1. Environment's HDRI can't be set with negative value;
2.Instance Master Hidden (Object Properties) doesn't work;
3.MXI cant be set as emitter source
Is it possible to save Environmen;s HDRI settings?
The first one, the 0 to 1 range represents 0 to 360 degrees so negative values aren't necessary. Probably though this param should be 0-360 for consistency with Studio.
EDIT: I see it does work as in Studio, so enter values between 0-360. The default slider though goes from 0 to 1, so this needs to be changed.
I confirm the other two bugs.
