By jfrancis
#358263
1)
I can't seem to get Maya Fur to work at all. I suspect it's not possible, but
http://support.nextlimit.com/display/ma ... ir+and+Fur
says:
It is important to note that MaxwellHair.mxx is not a fur/hair generator. It reads the fibers provided by a fur/hair generator (like Shave&Haircut, Maya Fur, Ornatrix, Softimage Hair, etc) and allows them to be rendered by Maxwell Render.
I assume the reference to fur is a typo
By jfrancis
#358264
2)
When I design a NURBS curve and attach a paint effects stroke I can get Maxwell to render it as a hair. I can't figure out how to give the hair 'cone' more than one radius. It's always a cylinder.
By jfrancis
#358265
3)
The Shave and a Haircut thing is a mess.
I spent something like $600 getting Shave 6 for Maya 2012. When the new Maxwell plugin came out I finallt upgraded to Maya 2013 and consequently seem to have lost Shave. There is no Shave for Maya 2013.
By Mihnea Balta
#358268
jfrancis wrote: I assume the reference to fur is a typo
Yes, it was a typo, I've fixed it now.
jfrancis wrote: When I design a NURBS curve and attach a paint effects stroke I can get Maxwell to render it as a hair. I can't figure out how to give the hair 'cone' more than one radius. It's always a cylinder.
Expand the "Pressure Mappings" rollup on the stroke, set pressure map 1 to "width" and use the graph control to set two control points, one for root width and one for tip width. The curve will scale the width set in the brush node. Alternatively, you can set the brush node to create tubes and use the width scale controls in the Tubes rollup.
jfrancis wrote: I spent something like $600 getting Shave 6 for Maya 2012. When the new Maxwell plugin came out I finallt upgraded to Maya 2013 and consequently seem to have lost Shave. There is no Shave for Maya 2013.
Yeah, they're usually pretty slow to catch up to the latest Maya release, I don't know why. They'll release a build with support for 2013 eventually.
By jfrancis
#358293
Works fine on the Maya side but the Maxwell hair vanishes (except for one dot at one end) in the Maxwell render side as soon as I change pressure 1 mapping to width.
Mihnea Balta wrote:Alternatively, you can set the brush node to create tubes and use the width scale controls in the Tubes rollup.
Works, but I get a 'thorns on a vine' effect along the stroke instead of one long hair from the stroke. Is this expected behavior?
By Mihnea Balta
#358298
jfrancis wrote: Works fine on the Maya side but the Maxwell hair vanishes (except for one dot at one end) in the Maxwell render side as soon as I change pressure 1 mapping to width.
Make sure you're not making the root thinner than the tip. Maxwell hair has this limitation at the moment, it can't render fibers which get thicker towards the tip. I've uploaded a scene file here which shows a stroke with pressure mapping for width.
jfrancis wrote: Works, but I get a 'thorns on a vine' effect along the stroke instead of one long hair from the stroke. Is this expected behavior?
Yeah, in that case the stroke acts as a generator curve and the tubes grow from it.
By jfrancis
#358299
Great. Thanks.
So I should not use a wacom pen to try and build pressure variation into the stroke because while Maya sees the entire mapping, Maxwell only sees the t=0 and t=1 radii and the first has to be larger than the second.
And I see I can convert paint effects to polygons and render the shape as polygons as a possibility.
