#353002
In MXLrender we can uncheck the color channel and the MXI write ability. It works good, I use this feature to render many matériel ID via différent renderlayer on Maya (RVB pass are often used on compositing for mask in animation sequence).
But when I tried to render my MXS sequence on the network, it doesn't work because Monitor try to move the final render MXI on the output folder even if the MXI/color is uncheck.
To counter this bug I just render color/MXI with basic mat on all my object but the render time is bigger and in my mind a bit too much for an simply ID pass.
Config :
Maya 2011 x64 - Maxwell 2.6.0 x64.
No EXR support?
Will do, thank you!
Even Luis bugged :D Poor of us! I got another […]
Maya plug-in MR 5.2
Can someone from NL answering this question please[…]
Maxwell Render V5 Series
"Investing in Marketing is important for any […]
