By arch3d
#351282
Hi all,
I use simple scatter tool for ICE. If i try to render i got spheres only. I found in manual that is normal behavior. Any hope for scatter support in new update of plugin?
And you want to see instances of your objects? Please send me a simple scene, or give more info. Particle instances should work ok. As well as regular instances.
By arch3d
#351313
Mihai,
I use simple scatter compound: http://www.vfxarea.com/?p=215
Here is a problem:
1.I have simple scene:
2.I use scatter tool:
3.Here is render region preview in MentalRay:
4....And in Maxwell:
5. If i use default shapes (e.g.boxes):
6. I have such result:
Thank you for help
By mixepix
#351314
Try setting the scale (not the size) when you are using instances, otherwise I think Maxwell sets it to 0,0,0
By arch3d
#351321
mixepix wrote:Try setting the scale (not the size) when you are using instances, otherwise I think Maxwell sets it to 0,0,0
It doesn't help:( By the way regular instances work perfect.
I think it's a problem with the Add point node and instance shape in this case. I'll let the plugin developers know, thanks for the screenshots :)
EDIT: it does work correctly however with the Emit from geometry node, and hooking an instance shape in there. Might be a workaround for now.
By arch3d
#351392
Thank you!!!
On my wishlist are also material preview in render tree and shader color in texture decal mode if i don't use any texture :P
