By gadzooks
#350962
Marton i have a project im working on. I have two files, one is a building the other is the site. I made the building a mxs file and then used a proxy inside of the site file to place the building. The building came in fine as the proxy but then modo would never export it. Modo eventually crashed and now Modo will not open the site file which contains the proxy at all. Modo will crash as soon as it reaches 100% load. I have pm you the location to the files. Thanks Gadzooks
By Marton Day8
#350991
One question:
Does it work if you create a new scene with only the Maxwell Proxy object (loaded with the mxs scene)? Does the export finish fine?
Márton
