- Thu Dec 22, 2011 3:18 pm
#350879
so after a render in que finished while merging the free nodes started (coop) to render the next item and 4 of 6 nodes disconnected. The remaining 2 continued to render just fine.
[22/December/2011 08:08:47] All the nodes have sent the MXI file. The merging process can start.
[22/December/2011 08:08:48] Start merging process...
[22/December/2011 08:08:48] Node pw44 has sent MXI file.
[22/December/2011 08:08:48] ERROR: Rendering process has failed in node: PW57: 192.168.3.52
[22/December/2011 08:08:48] Processing cooperative job: 5
[22/December/2011 08:08:48] Sending job order to node: PW57
[22/December/2011 08:08:48] ##### Processing pending jobs #####
[22/December/2011 08:08:48] ##### Job 5 #####
[22/December/2011 08:08:48] ### Job type: cooperative ###
[22/December/2011 08:08:48] ### Assigned to: any node available ###
[22/December/2011 08:08:49] ERROR: Rendering process has failed in node: PW64: 192.168.3.28
[22/December/2011 08:08:49] Processing cooperative job: 5
[22/December/2011 08:08:49] Sending job order to node: PW64
[22/December/2011 08:08:49] ##### Processing pending jobs #####
[22/December/2011 08:08:49] ##### Job 5 #####
[22/December/2011 08:08:49] ### Job type: cooperative ###
[22/December/2011 08:08:49] ### Assigned to: any node available ###
[22/December/2011 08:08:52] ERROR: Rendering process has failed in node: PW58: 192.168.3.12
[22/December/2011 08:08:52] Processing cooperative job: 5
[22/December/2011 08:08:52] Sending job order to node: PW58
[22/December/2011 08:08:52] ##### Processing pending jobs #####
[22/December/2011 08:08:52] ##### Job 5 #####
[22/December/2011 08:08:52] ### Job type: cooperative ###
[22/December/2011 08:08:52] ### Assigned to: any node available ###
[22/December/2011 08:08:55] ERROR: Rendering process has failed in node: pw44: 192.168.3.10
[22/December/2011 08:08:55] Processing cooperative job: 5
[22/December/2011 08:08:55] Sending job order to node: pw44
[22/December/2011 08:08:55] ##### Processing pending jobs #####
[22/December/2011 08:08:55] ##### Job 5 #####
[22/December/2011 08:08:55] ### Job type: cooperative ###
[22/December/2011 08:08:55] ### Assigned to: any node available ###
[22/December/2011 08:08:58] ERROR: Rendering process has failed in node: PW63: 192.168.3.49
[22/December/2011 08:08:58] Processing cooperative job: 5
[22/December/2011 08:08:58] Sending job order to node: PW63
[22/December/2011 08:08:58] ##### Processing pending jobs #####
[22/December/2011 08:08:58] ##### Job 5 #####
[22/December/2011 08:08:58] ### Job type: cooperative ###
[22/December/2011 08:08:58] ### Assigned to: any node available ###
[22/December/2011 08:09:01] ERROR: Rendering process has failed in node: PW5: 192.168.3.60
[22/December/2011 08:09:01] Processing cooperative job: 5
[22/December/2011 08:09:01] Sending job order to node: PW5
[22/December/2011 08:09:01] ##### Processing pending jobs #####
[22/December/2011 08:09:01] ##### Job 5 #####
[22/December/2011 08:09:01] ### Job type: cooperative ###
[22/December/2011 08:09:01] ### Assigned to: any node available ###
[22/December/2011 08:09:04] Render node: PW64: file_dependency_sent: 8001-10GR.mxs
[22/December/2011 08:09:05] Render node: PW58: file_dependency_sent: 8001-10GR.mxs
[22/December/2011 08:09:05] Render node: PW64: file_dependency_sent: 8001-10GR.mxs
[22/December/2011 08:09:05] ERROR: Rendering process has failed in node: PW64: 192.168.3.28
[22/December/2011 08:09:05] ERROR: Render node PW64 has reached the maximum number of failures permitted and it will be closed.
[22/December/2011 08:09:06] ERROR: Rendering process has failed in node: PW57: 192.168.3.52
[22/December/2011 08:09:06] ERROR: Render node PW57 has reached the maximum number of failures permitted and it will be closed.
[22/December/2011 08:09:06] ERROR: Rendering process has failed in node: PW64: 192.168.3.28
[22/December/2011 08:09:06] ERROR: Render node PW64 has reached the maximum number of failures permitted and it will be closed.
[22/December/2011 08:09:06] Warning: Render node disconnected: PW64
[22/December/2011 08:09:06] ERROR: PW64 has failed while sending/receiving dependencies. Trying to recover..
[22/December/2011 08:09:06] ERROR: It is not possible to restore dependencies after this failure.
[22/December/2011 08:09:07] Render node: PW57: file_dependency_sent: white.hdr
[22/December/2011 08:09:07] ERROR: Rendering process has failed in node: pw44: 192.168.3.10
[22/December/2011 08:09:07] ERROR: Render node pw44 has reached the maximum number of failures permitted and it will be closed.
[22/December/2011 08:09:08] ERROR: Rendering process has failed in node: PW63: 192.168.3.49
[22/December/2011 08:09:08] ERROR: Render node PW63 has reached the maximum number of failures permitted and it will be closed.
[22/December/2011 08:09:08] ERROR: Rendering process has failed in node: PW57: 192.168.3.52
[22/December/2011 08:09:08] ERROR: Render node PW57 has reached the maximum number of failures permitted and it will be closed.
[22/December/2011 08:09:08] Warning: Render node disconnected: PW57
[22/December/2011 08:09:08] ERROR: PW57 has failed while sending/receiving dependencies. Trying to recover..
[22/December/2011 08:09:08] ERROR: It is not possible to restore dependencies after this failure.
[22/December/2011 08:09:09] ERROR: Rendering process has failed in node: PW63: 192.168.3.49
[22/December/2011 08:09:09] ERROR: Render node PW63 has reached the maximum number of failures permitted and it will be closed.
[22/December/2011 08:09:09] Warning: Render node disconnected: PW63
[22/December/2011 08:09:09] ERROR: PW63 has failed while sending/receiving dependencies. Trying to recover..
[22/December/2011 08:09:09] ERROR: It is not possible to restore dependencies after this failure.
[22/December/2011 08:09:09] ERROR: Rendering process has failed in node: pw44: 192.168.3.10
[22/December/2011 08:09:09] ERROR: Render node pw44 has reached the maximum number of failures permitted and it will be closed.
[22/December/2011 08:09:09] Warning: Render node disconnected: pw44
[22/December/2011 08:09:09] ERROR: pw44 has failed while sending/receiving dependencies. Trying to recover..
[22/December/2011 08:09:10] Render node: PW58 Job ID: 5 sl: 1
[22/December/2011 08:09:11] Merging process finished successfully!
[22/December/2011 08:09:11] MXI saved in: \\Pw64\mxs\8001-10BL.mxi
[22/December/2011 08:09:12] Render node: PW5 Job ID: 5 sl: 1
[22/December/2011 08:09:14] Render node: PW58 Job ID: 5 sl: 2.00211
- By Matteo Villa
