By Luca_Studioaltieri
#349777
Ciao,
in network render if i change target SL it will affect only "the next frames", and it will not affect the frames that are running in nodes.
This happens also to coop mode.
... so .... If il set a lower SL, nodes continue to render the job until they reach the original SL parameters.
(and while rendering from new SL to old SL it will not update SL number & timing in the maxwell monitor = it makes useless the edit SL button)
Ciao
Luca
