#348814
Please use this forum for posting issues you believe to be common to both the Standalone and Render Suite versions of the plugin. For issues you believe to be specific to one or the other, please use the appropriate sub-forum:
In the interest of saving time, when posting in this forum, please indicate which plugin you are using; in most cases, it will not make a difference, but for more obscure issues, it may. If your forum signature does not already indicate, please also specify:
  • the version number of the plugin you are using
  • which version of SketchUp you are running
  • which operating system you are using
