By m-Que
#339384
Turns out, in Studio, when you hit the 'Reset' button, while you have a group selected, it not only resets the pivot position to 0,0,0, but it also drags the group along with it, moving it for some reason to the position where the group has been created.
This does not happen, when you have an object (or a few objects) selected.
Is this a known issue (a bug?), o perhaps this is meant to be that way?
Thanks
By Half Life
#339385
Things get even weirder if you:
1) Select an object in the group and move it
2) Close the Group
3) Move the Group
4) Reselect the object from step one and center then reset
Odd.... it looks like it is re-adding the transformation(s) of the group each time it resets.
Here's a video: http://www.spotoarts.com/jason/resetglitch.zip
Best,
Jason.
By m-Que
#339386
Yeah, and there's more of similar stuff like that...
I was playing around with it all day, trying to understand where the problem lies.
For example, sometimes after saving & reloading the scene, pivots change their position and rotation angle, so you cannot manipulate with those groups anymore.
