By frosty_ramen
#337442
I just noticed something odd, a node looks to be hung-up/froze. in my monitor it shows received file 10/10, but has not moved on from here. in the nodes dialog it shows it is rendering fine.
any suggestions
By frosty_ramen
#337454
Then when rendering has finished the node has an error "unable to open file for sending", and it freezes the monitor untill the node is closed.
By dariolanza
#337632
Hello frosty_ramen,
We are currently working on the network system, and I guess that it is solved in the latest version we are developing right now.
If you want to test it (although it is still in beta state) please write us to the Technical Support, and we will send you the latest development to check if the issue is already fixed.
Greetings
Dario Lanza
