#335664
Maxwell for SolidWorks
Version 2.5.1 Release Notes
Version 2.5.1 of the Maxwell for SolidWorks plugin is mainly a bug-fix update.
Changes
  • Added ability to save Maxwell Fire image
Fixes
  • IBL Intensity now updates Maxwell Fire
  • Maxwell Fire could hang in some cases
  • Maxwell Fire could refresh unnecessarily
Notes
  • This version of the plugin implements a new user-preferences system. If you are using a customized plugin color scheme, it is therefore advised that you save your current color scheme to a file (Scene Manager > Options toolbar > Save UI Colors File) before installing this update so that you can re-import it afterward. This plugin also uses new default color schemes; if you prefer the old default color scheme (i.e. dark, Maxwell-style), it is available in the file classic.xml, which you will find if you click Scene Manager > Options toolbar > Load UI Colors File.
Downloads (please do not share these links):
  • (version superseded)
Please post any issues you find with this build in this thread.
Cheers,
JD
