By itsallgoode9
#335588
I have a handful of renders I need to do, so put all of the scene files into the network monitor to do a batch but for some reason, the rendered images refuse to follow the paths setup in the scene file. If I manually render, the images go to the correct folder, but I cannot make it do that when doing a batch. What am I doing wrong?
also, if I try to use the "single file" option, I get an error saying "image output is not a valid network..." "mxi path is not a valid network..."
