By m-Que
#334615
Looks like a bug -
Fire does not react to UV operator changes; even if you move around the scene etc.
You have to stop and restart Fire to see changes.
Can someone please confirm this?
By m-Que
#334627
tom wrote:You're modifying the corresponding UV channel, right?
Yes, I select an objects UV set, click on Operator, apply the desired changes, I see those changes in navigator but not in Fire. I have to manually restart it to see those changes being applied.
