- Sat Aug 21, 2010 2:07 pm
#329247
I have problem with newest plug-in, it tries to run the monitor regardless if it is already running or not. In the case if monitor is already running I am just getting error about another instance that will not run. When I run it w/o Monitor running it does run the new one but the scene does not pick up.
So now I need to load the scene manually. I will try to reinstall old plug-in later to check if it is not the Maxwell issue (I have reinstalled Maxwell in new location on the hard drive).
EDIT: I have checked old plug-in and it works fine, so it must be the plug-in not my configuration.
EDIT2: I have reinstalled Windows on controller machine and everything seems to be working OK now. Silly computers! ...and sorry for false alarm.
Cheers
Tomek
Tomek
