#327758
Using v2.1 the Maxwell Network Monitor is reporting incorrect SL after the job is completed.
In the screenshot above you'll notice that for Job 2 it reports that RENDER7-PC ended with an SL of 0. I don't have the actual SL but it was higher than the other computer which ended with 8.321. This also incorrectly translates to the final combined SL which ended up around 12.3 rather than the reported 8.321.
You'll also notice that in Job 3 which is currently running, that it is reported correctly. Similarly Job 2 was being reported correctly until the job was completed. I'll try and remember to post another screenshot after Job 3 completes.
-Brodie
#327768
Here's the screenshot after Job3 finished. Again, you can see that after it's done the first computers info disappeared for some reason. Note that this is only a reporting issue in Monitor. Everything is coming out just fine in the merging and output process.
