- Fri Jan 29, 2010 4:40 pm
#318290
Maxwell for Cinema 4D V1.8.1.8 has been released to the public. Here are the details:
- V1.8.1.8 (for Maxwell 1.x)
- Release Notes
Version 1.8.1.8 of the Maxwell for Cinema 4D plugin is a minor bug-fix update which also introduces compatibility with Cinema 4D R11.5. Following are some of the particulars.
Changes
- added support for Cinema 4D R11.5 (there are two downloads, one for R9.6-R11 and one for R11.5)
- Cinema 4D R11.5’s new ‘Render Instance’ feature is supported automatically
- added new real-time feedback for tile/offset/etc. in the plugin’s texture editor
- texture tile/offset/etc. are now shown in the Cinema viewport
- added CTRL/SHIFT key modifiers to texture editor to allow adjusting multiple textures at once
- improved the appearance of Maxwell materials in the Cinema renderer
- added new Object Properties: ‘Ignore Normal tag’ and ‘Ignore Phong tag’
- an object’s material would be copied when the object was copied
- Cinema material alpha was not translated properly in some scenarios
- Cinema XRef materials were not read correctly when the XRef was under another object
- crashes could occur when reading certain types of TIF files
- lights could be exported even when their render dots (or layers in R11) were switched off
- transparency and luminance are ignored in Cinema materials if they are pure black with no texture
Next Limit Team
- By Jochen Haug
