- Fri Jan 29, 2010 4:35 pm
#318288
Maxwell for Cinema 4D V2.1.3.0 is now released to the public. Here are the details:
- V2.1.3.0 (for Maxwell 2.x)
- Release Notes
Version 2.1.3.0 of the Maxwell for Cinema 4D plugin is a minor bug-fix update which also introduces compatibility with Cinema 4D R11.5. Following are some of the particulars.
Changes
- added support for Cinema 4D R11.5 (there are two downloads, one for R9.6-R11 and one for R11.5)
- Cinema 4D R11.5’s new ‘Render Instance’ feature is supported automatically
- added a ‘Link MXM’ field to the main Maxwell material page
- material editor UI now shows a duplicate of the Attribute Manager UI for MXM Linked materials
- added MXM Gallery browsing button the Attribute Manager material UI
- added new Object Properties: ‘Ignore Normal tag’ and ‘Ignore Phong tag’
- fixed an issue caused by running in 64-bit mode under OSX Snow Leopard
- fixed an issue with the render low priority switch not working
- scattering is now set to 0.0 as default to prevent maxwell.exe rendering it even when disabled
- transparency and luminance are ignored in Cinema materials if they are pure black with no texture
Next Limit Team
- By Matteo Villa
