By claus
#310751
"Focus to" is somehow broken. Sometimes it works sometimes it don't. Maybe I'm imagining this but it seems that if i right-click in the upper part of the viewport window to activate the contextural menu, then select "focus to" it works more often. If I right-click in the bottom part of the window the contextural menu extends downwards beoynd the camera window and covers part of the color picker. In this case the "focus to" command is selectable but does not work...
Claus
MacOSX snow leopard...
Update:
I must add that even in the second situation where the "focus to" command actually seems to change the focus values, it does not do that correctly and the focus ends up way off. Somethings wrong!
