By juan
#309692
Well, it seems the cooperative job succeeded but after that the manager was disconnected. Was it done manually? After that it's connected again, was it intended? Otherwise it seems like you are getting interrupted connections in your network.. Anyway the cooperative job worked, the log says the final MXI was sent to the manager, if you open it and go to menu/open temp folder, a subfolder is created for each job. If for any reason there was a problem, the MXI files should still be there so you could recover your work.
Thanks,
Juan
By frosty_ramen
#309697
i am unsure why the manager disconnected there was an error pop-up. the reconnecting of the manager was me, the mxi was never saved. and after all this the nodes would not continue to the next render in que. i have to close the monitor and manager then reopen and add jobs again.
