#304278
Hello:
Currently, to set Maxwell attributes on an object, you select an object with the FormZ "Attributes" tool and then apply Maxwell attributes to the object. This works fine on a single object.
Recently, I had about 50 objects that I wanted to set the Maxwell attribute on (all the same attributes). I had to do it one at a time. Am I missing something?
The FormZ "set attributes" tool is designed exactly for this. Multiple objects can have attributes assigned at once. Can the Maxwell attributes show up in their own tab on the FormZ "set attributes" tool?
Thanks,
Gary
