By gotoxy av-media
#293876
please post a reference image how it should look like!
munch
By blueplanetdesign
#293918
Frosty...
Which modeler are you using?
Check xenomorphic.co.uk for some nice materials. They are located in the "education" section of this site.
Of particular interest is the engineering crosshatch material. It might provide a nice place to start.
Here's a quick render done in MAX using the material I refer to...
This is the bitmap that the material uses to achieve the crosshatch effect.
As you can see, one could easily create one more in keeping with your "sketchy" pencil look and get closer to what you want.
Good luck!
bpd
Last edited by blueplanetdesign on Fri Mar 13, 2009 2:15 am, edited 1 time in total.
By blueplanetdesign
#293920
Yep. Max has the answer.
Great look.
I think it's pretty close to what Frosty is after.
Oh, I forgot to mention that my suggestion is a free downloadable MAX file.
bpd
By gotoxy av-media
#293927
very nice toon shaders MAX!
i also would prefer rendering toon-style-images with other renderengines...
here is my quick attempt rendered with maxwell:
By frosty_ramen
#293937
Blueplanetdesign thanks for the suggestion, i do use 3ds max but i'll have to find a way to import my models into max from the format that i receive them from our engineer (solid works).
Magnus, ah those are what i was looking for! but no c4d. :x I love the timer and the mouse!
Gotoxy av-media, i have don some similar things in studio but i wish i could achieve a 'hidden line' sketch.
By gotoxy av-media
#293938
...just the same way you did it!
as you already said before there is no way generating a toon-style-mxm...
1. apply a toon shader to the teapot
2. convert the toonstrokes to poly (outlines)
2. assign ags to the teapot (fill-color)
munch
By gotoxy av-media
#293940
@MAX
nice to hear that from the master of mxms!
@frosty
hidden line?! hmm, you can achieve very different toon-styles...
i will do some tests!
munch
By frosty_ramen
#293943
Gotoxy
in what program are you selecting toon shader?
By gotoxy av-media
#293948
frosty,
i am using maya2009!
toon works pretty well and you can even apply painteffects to the toonlines...
btw. hidden line is supported!
not a beauty but it works:
munch
