By mackshiva333
#293810
Maxwell studio saves all geometry in the mxs file. Does it need to do this?
Wouldn't it be better if it just saved links to the geometry and any changes to it that have been done in studio could be saved in the file and executed when the file is loaded. When you're doing many iterations of a project you wind up using a lot of disc space to save the same geometry over and over.
Most professional 3D software just saves a link to any imported geometry. Generally there is an option to save geometry with the file if you wish. I thin this would be a big improvement.
Thanks
Thanks, will try - got bogged down with other thin[…]
