#293220
Open the (grass) material you have applied to the ground plane in the plugin's material editor, click the top node in the layers tree to show the main material parameters page, and check the Shadow checkbox under Rendering Options. Only materials with this option enabled will receive shadows when rendering the shadow channel.
By adri
#293221
Thanks JD !!!!
By adri
#293237
Thanks for the help JD.
Jsut as a follow up is it possible to output to a multilayered tif file in one render? Or has each layer got to be rendered out seperately?
TIA
Adri
#293243
No problem, and no, rendering out to separate images for each channel is just how Maxwell works. They're all rendered at the same time though, so the only real difference is that you have to comp them together however it works best for each particular scenario.
By adri
#293297
hmmm...Overnight render fails on the shadow pass! Shi&!!
Here's the RGB with clear tree shadows:
And here's the shadow pass with no tree shadows:
Can anyone help with this? I haven't a clue what's wrong.
TIA
Adri
By adri
#293328
It'd be very welcome if someone could comment on this...nudge nudge...
Thanks
Adri
#293329
I don't use the feature much, so I can really only tell you how to turn it on - you might want to re-post it as a more general shadow-channel related question in the Maxwell Render section of the forum.
By adri
#293335
Willdo, thanks for the help.
#293342
For what it's worth, I tried to duplicate what I see in your images (trees, grass plane, sun, etc.) , and the shadow channel is working fine, so maybe you also want to include some information about how you're building the materials - there could be some clues there.
