#290081
Version 1.8.1.3 of the Maxwell for Cinema 4D plugin has been released. This is a minor bug-fix version:
Changes:
  • Export now uses either the current Cinema Basic Units, one of several unit presets, or a custom multiplier
  • The plug-in now supports export of multiple cameras
Fixes:
  • Polygon objects could become triangulated on export
  • Render dots were not being respected correctly in some hierarchies
  • Invert/ Soft/ Image Alpha could be interpreted incorrectly when translating Cinema materials
  • Auto-generated Instances could be located incorrectly
  • Maxwell Instances could interfere with Cinema instances
  • Maxwell Instance objects could show an incorrect bounding box
  • Maxwell Emitters were not shown correctly in the Cinema viewport
  • Invalid texture paths would not be corrected if they used forward-slash UNC format
