#288323
Hi everyone- Sorry about the cross post- I should have posted here first but I usually post in the Rhino forum so.....
I have been using brushed finishes quite a bit but have been having an issue with my material looking VERY different on different shaped objects or even on objects where I have the brushed finish going in a different direction.
Is there something that I can do differently with my material that would make it more translatable to different shapes? I don't want to waste a lot of time fiddling with bump and displacement for every model that I create. Or is this something that is normal to do? Here is a screen shot of some sample shapes with the exact same material applied but the brushed finish is traveling in different directions. Thanks in advance
Here are some screen shots of my material
By MS
#288327
UV mapping is what you are looking for...
MS wrote:UV mapping is what you are looking for...
Yes. The size of your scratches in your examples are different. Proper UV mapping will get you the results you want for materials like this.
