By robin of nottingham
#288000
in rhino : rhino options : render mesh quality
does this setting effect the render quality at all.... I was thinking it was just for the shaded viewports. I have it on jagged and faster usually. Will this effect the quality of render when rendering in maxwell or has it no effect at all?
thanks,
r
By Polyxo
#288002
Maxwell and pretty much any renderer can only deal with meshes. The engine does not care about your Nurbs-model at all but is only interested in its polygonal representation.
So yes - the settings here are crucial for quality and speed of your renderings.
#288004
I am always thinking that my renders dont look crystal sharp on the edges perhaps this is the mesh settings screwing stuff up?
I know that some jewellers scale their models by 10 but this then wrecks the material properties in some cases.
what mesh settings would you advise for jewellery sized objects? thanks,
r
By Polyxo
#288005
robin of nottingham wrote:I am always thinking that my renders dont look crystal sharp on the edges perhaps this is the mesh settings screwing stuff up?
r
It is unfortunately impossible to give general advice on mesh settings. This depends on the topology of your objects. Round shapes like spheres generally need denser mesh settings than - say a cube. For starters I recommend reading all render-mesh releated sections of the Rhino help file. There is also a mesh-section in the Rhino Wiki. Note that it is possible to assign per object mesh settings (in object-properties)
The sharpness problem you mention however will likely have to do with something else: Smoothing. Here the help section for the Weld/Unweld command will get you started. I would not advice to scale your objects up.
It will certainly not help in terms of meshing and smoothing but will lead to unrealistic lighting and DOF conditions.
Hth, Holger
#288006
does the higher the iso settings also make the image more grainy? I seem to remember something in my art college days about the faster the film the more grainy the image but is that true in maxwell?
thanks,
r
By Polyxo
#288007
robin of nottingham wrote:does the higher the iso settings also make the image more grainy? I seem to remember something in my art college days about the faster the film the more grainy the image but is that true in maxwell?
thanks,
r
You remember correctly but this is not the case with Maxwell.
