By mtripoli
#285512
A question; do suppressed features "count" when rendering? For instance, if I have a screw with threads. If I render the screw in its normal state it renders as shown (with threads). If I suppress the threads, once Maxwell gets a hold of it does it internally "unsuppress" the threads? In other words, is it rendering only what the current model is as seen? Is this making sense at all? :roll:
Thanks for putting up with my jibberish...
#285513
Yes, the plugin's job is to take the meshes you see in the viewport and put them into the MXS, so if you have suppressed the threads on a screw, it should be written into the MXS as a smooth pin.
By mtripoli
#285523
Thanks!
