By Asmithey
#282506
Hello,
I am trying to move some instances around in studio but I can not pick them. Some I can pick and some I can not. Even if I do select all they do not get picked. Also, there object number does not appear in the objects dialogue box.
Is this a bug?
Aaron
Make sure you are in instance selection mode. Select the object that has instances, you will see it's instances appear in the Instances panel and you can either select them there or in the viewport if you are in Instance selection mode.
By Asmithey
#282559
Thank you,
I will try that.
