By Kabe
#27273
To allow parallel rendering, it would be very useful, if the seed parameter for the rendering could be set as a parameter.
As it is now, if you render the same file on two machines to the same level, they have exactly the same noise distribution.
If you would provide a seed value as render parameter, you could render a file on n machines, and later get one image out of the n results which has a reduced noise.
See the discussion here:
http://www.maxwellrender.com/forum/view ... 7271#27271
Cheers
Kabe
By DELETED
#27279
DELETED
did you tried luxCore?
