By numerobis
#276708
hi,
i tried to position a hdri using the sketchup plugin... but it seems that the offset is not working properly.
rotation has no effect when i render directly. opening the mxs in studio i get an offset of 1000.00 instead of 37.00!
am i doing something wrong inserting 37.00 within the plugin or is this a bug?!? :roll:
By pelias
#276897
Unfortunately SketchUp plugin uses different units for offset than Studio. If you enter offset 0.1 in SU you get offset 10 in Studio. Other than that the effect of offset should be the same.
Hope this helps.
