By spuffles
#274552
After considerable playing around and going through a bunch of other posts(thanks guys) our X2200s are up and rendering:)
Issues:
-Unexpected crashing mid render, this apparently happened because Manager was running under windows and got fixed once running on Suse.
-Windows box crashed on coop, although this might be just my box so please post if you have this issue....
-I had an issue with my XSI exporter where I would get texture address errors that were set up correctly, this got fixed by opening the exported scene in studio and re saving. Please post if you get this problem with a different exporter as for now I'm not sure if its just an XSI plugin issue.
-Cant get studio to open under linux, Environment variables seam to be set correctly when I check 'env', and everything else works.
-I need to pry at mxcl for it to run, It goes up and works fine after 3 to 6 tries... this is annoying and could be an issue.
-I'm getting some artifacts on the coop preview(green horizontal poopy), this is from mxcl under windows, not that big of a deal...
Everything else looks good, coop working fine, single frame working fine...
As a "for now" thing, I'm running the server software trough VCL windows of the different servers.... Sloppy but I'm pressed for time... I'm sure this is not what people do for 100 servers... Any information on how to set up mxcl as an automatic process.. a link.. some pointers.. would be great. Anyway I'll try to do this when I have time, I'm sure there are tons of sources on how to do this, I'll let you know if I get it done...
Cheers.
