By Daniel Hruby
#261962
So after about 4 hours of work on this file trying to optimize the scene AND get the network render going I have hit an obstacle. I can successfully get the two machines to CoOp on one MXS from a Pack and Go folder in my Public Folder on the MacPro. But two times now, after about 25-30 minutes of rendering, the MacPro MXCL Crashes.
If I relaunch MXCL, I see the queue. appears that both machines are still "rendering", but I assume that is wrong and that only the G5 is still rendering. So I stop the co-op in the queue and the MXI gets merged from the other machine and it says Success!.
If I then re-add the original MXS again to the job queue, it seems to pick up again where it left off and I can get both machines rendering again, but I can no longer display the images from either node or the Co-Op image. If I click display Co-op render, it says computing image, but it goes away afetr a couple minutes and I never see tabs to view an image like I could before the crash.
EDIT: This morning, both computers were still cranking away, but when I stopped the Job, MAXCL Crashed on the MacPro right beofre it finished merging. I tried to restart the job again hoping I could stop it and get the merged MXI, but it started everything over again from SL 0. A waste of time and power running both machines full bore over night.
Stats of MacPro server at time of crash:
Stats of G5 Quad at Time of crash:
After relaunching MXCL, succesful merging of MXI and adding the MXS again to the queue:
You can see the MXI starts were it left off after crash....but no display shows after "computing image" disappears
MacPro after resuming Crashed Co-Op
G5 Quad after resuming (note the increase in Benchmark)
Here is the crash report in case it helps. Both times, this crash occurred on the MacPro (Manager) after about 30 minutes of Co-Op rendering.
Process: mxcl [39178]
Path: /Applications/Maxwell/mxcl.app/Contents/MacOS/mxcl
Identifier: com.nextlimit.mxcl
Version: ??? (1.6)
Code Type: X86 (Native)
Parent Process: launchd [261]
Date/Time: 2008-02-20 19:32:14.240 -0800
OS Version: Mac OS X 10.5.2 (9C31)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000004
Crashed Thread: 0
Thread 0 Crashed:
0 QtGui.dylib 0x005ed13c QApplicationPrivate::globalEventProcessor(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 956
1 com.apple.HIToolbox 0x93745fc3 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
2 com.apple.HIToolbox 0x937453fd SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
3 com.apple.HIToolbox 0x93745262 SendEventToEventTargetWithOptions + 58
4 com.apple.HIToolbox 0x93774520 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 356
5 com.apple.HIToolbox 0x9374637c DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134
6 com.apple.HIToolbox 0x937453fd SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
7 com.apple.HIToolbox 0x93761e0e SendEventToEventTarget + 52
8 QtGui.dylib 0x005e827a qt_mac_send_event(QFlags<QEventLoop::ProcessEventsFlag>, OpaqueEventRef*, OpaqueWindowPtr*) + 122
9 QtGui.dylib 0x005f3d8b QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 543
10 QtCore.dylib 0x002f84de QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 54
11 QtCore.dylib 0x002f8613 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 129
12 QtCore.dylib 0x002fac5b QCoreApplication::exec() + 179
Thread 1:
0 libSystem.B.dylib 0x90418b3a select$DARWIN_EXTSN + 10
1 libSystem.B.dylib 0x903f9c55 _pthread_start + 321
2 libSystem.B.dylib 0x903f9b12 thread_start + 34
Thread 2:
0 libSystem.B.dylib 0x903c89e6 mach_msg_trap + 10
1 libSystem.B.dylib 0x903d01dc mach_msg + 72
2 com.apple.CoreFoundation 0x935ef0de CFRunLoopRunSpecific + 1806
3 com.apple.CoreFoundation 0x935efd74 CFRunLoopRun + 84
4 com.apple.DesktopServices 0x962be46f TSystemNotificationTask::SystemNotificationTaskProc(void*) + 123
5 ...ple.CoreServices.CarbonCore 0x906a9beb PrivateMPEntryPoint + 56
6 libSystem.B.dylib 0x903f9c55 _pthread_start + 321
7 libSystem.B.dylib 0x903f9b12 thread_start + 34
Thread 3:
4 com.apple.DesktopServices 0x962be5e8 TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 216
Thread 4:
0 libSystem.B.dylib 0x903cfbce __semwait_signal + 10
1 libSystem.B.dylib 0x903fa8cd pthread_cond_wait$UNIX2003 + 73
2 ...ple.CoreServices.CarbonCore 0x906ab9d7 TSWaitOnCondition + 126
3 ...ple.CoreServices.CarbonCore 0x9068a8fe TSWaitOnConditionTimedRelative + 202
4 ...ple.CoreServices.CarbonCore 0x906ab654 MPWaitOnQueue + 208
5 com.apple.DesktopServices 0x962c9a7a TNodeSyncTask::SyncTaskProc(void*) + 84
6 ...ple.CoreServices.CarbonCore 0x906a9beb PrivateMPEntryPoint + 56
7 libSystem.B.dylib 0x903f9c55 _pthread_start + 321
8 libSystem.B.dylib 0x903f9b12 thread_start + 34
Thread 5:
0 libSystem.B.dylib 0x903f94c6 kevent + 10
Thread 6:
2 com.apple.ColorSync 0x90cba460 pthreadSemaphoreWait(t_pthreadSemaphore*) + 42
3 com.apple.ColorSync 0x90cccd92 CMMConvTask(void*) + 54
4 libSystem.B.dylib 0x903f9c55 _pthread_start + 321
5 libSystem.B.dylib 0x903f9b12 thread_start + 34
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
0 libSystem.B.dylib 0x903c8a46 semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x903fadaf _pthread_cond_wait + 1244
2 libSystem.B.dylib 0x903fc633 pthread_cond_timedwait_relative_np + 47
3 com.apple.Foundation 0x95e8e4fc -[NSCondition waitUntilDate:] + 236
4 com.apple.Foundation 0x95e8e310 -[NSConditionLock lockWhenCondition:beforeDate:] + 144
5 com.apple.Foundation 0x95e8e275 -[NSConditionLock lockWhenCondition:] + 69
6 com.apple.AppKit 0x913a77f0 -[NSUIHeartBeat _heartBeatThread:] + 753
7 com.apple.Foundation 0x95e485ad -[NSThread main] + 45
8 com.apple.Foundation 0x95e48154 __NSThread__main__ + 308
9 libSystem.B.dylib 0x903f9c55 _pthread_start + 321
10 libSystem.B.dylib 0x903f9b12 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x005ecd91 ecx: 0xbfffee58 edx: 0x00000000
edi: 0x01325330 esi: 0x01316ae0 ebp: 0xbfffef88 esp: 0xbfffec60
ss: 0x0000001f efl: 0x00010282 eip: 0x005ed13c cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000004
Binary Images:
0x1000 - 0x20fff3 +com.nextlimit.mxcl ??? (1.6) /Applications/Maxwell/mxcl.app/Contents/MacOS/mxcl
0x290000 - 0x36307b +QtCore.dylib ??? (???) /Applications/Maxwell/Libs/QtCore.dylib
0x5b0000 - 0x96f7f2 +QtGui.dylib ??? (???) /Applications/Maxwell/Libs/QtGui.dylib
0xb60000 - 0xb8ba4e +QtNetwork.dylib ??? (???) /Applications/Maxwell/Libs/QtNetwork.dylib
0xba7000 - 0xbb3fe7 com.apple.opengl 1.5.6 (1.5.6) <d599b1bb0f8a8da6fd125e2587b27776> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0xbbb000 - 0xbf9ff7 libGLImage.dylib ??? (???) <090de775838db03ddc710f57abbf6218> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0xc03000 - 0xc5cff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0xc70000 - 0xc90ff2 libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0xca0000 - 0x1173fde libGLProgrammability.dylib ??? (???) <a3d68f17f37ff55a3e61aca1e3aee522> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x1203a000 - 0x12048feb libSimplifiedChineseConverter.dylib ??? (???) <548d5a699dbe2bb8fcc8275321fdc0d4> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x1204d000 - 0x1205ffff libTraditionalChineseConverter.dylib ??? (???) <89ec94121ef50601dc538548caae57fc> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x121cf000 - 0x121d0ff3 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x16a49000 - 0x16b37fef com.apple.RawCamera.bundle 2.0.2 (2.0.2) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x17b10000 - 0x17b82fff com.apple.iLifeMediaBrowser 1.0.5 (205.0.2) <2b5c1b0df3f8c76476791f8317fc7324> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x17bc9000 - 0x17bd3ffe com.apple.URLMount 3.1 (3.1) <742db901c626729373961d2b99036aab> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
0x1b70c000 - 0x1b711ff3 libCGXCoreImage.A.dylib ??? (???) <978986709159e5fe9e094df5efddac1d> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x8fe00000 - 0x8fe2da53 dyld 96.2 (???) <7af47d3b00b2268947563c7fa8c59a07> /usr/lib/dyld
0x90003000 - 0x90030feb libvDSP.dylib ??? (???) <b232c018ddd040ec4e2c2af632dd497f> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x90031000 - 0x903c7ff7 com.apple.QuartzCore 1.5.1 (1.5.1) <665c80f6e28555b303020c8007c36b8b> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x903c8000 - 0x90527ff3 libSystem.B.dylib ??? (???) <4899376234e55593b22fc370935f8cdf> /usr/lib/libSystem.B.dylib
0x90528000 - 0x9054cfff libxslt.1.dylib ??? (???) <4933ddc7f6618743197aadc85b33b5ab> /usr/lib/libxslt.1.dylib
0x9054d000 - 0x9056bff3 com.apple.DirectoryService.Framework 3.5.1 (3.5.1) <96407dca4d6b1d10ae5ca1881e31b27a> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x9056c000 - 0x90660ff4 libiconv.2.dylib ??? (???) <c508c60fafca17824c0017b2e4369802> /usr/lib/libiconv.2.dylib
0x90661000 - 0x9093aff3 com.apple.CoreServices.CarbonCore 785.8 (785. <827c228e7d717b397cdb4941eba69553> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9093b000 - 0x9093efff com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9093f000 - 0x909cafff com.apple.framework.IOKit 1.5.1 (???) <a17f9f5ea7e8016a467e67349f4d3d03> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x909cb000 - 0x90a7dffb libcrypto.0.9.7.dylib ??? (???) <330b0e48e67faffc8c22dfc069ca7a47> /usr/lib/libcrypto.0.9.7.dylib
0x90a7e000 - 0x90b5dfff libobjc.A.dylib ??? (???) <a53206274b6c2d42691f677863f379ae> /usr/lib/libobjc.A.dylib
0x90b5e000 - 0x90b84fff libcups.2.dylib ??? (???) <85ce204da14d62d6a3a5a9adfba01455> /usr/lib/libcups.2.dylib
0x90c87000 - 0x90d52fff com.apple.ColorSync 4.5.0 (4.5.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x90d53000 - 0x90d61ffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x90d62000 - 0x90d62ffe com.apple.quartzframework 1.5 (1.5) <4b8f505e32e4f2d67967a276401f9aaf> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x90d96000 - 0x90df0ff7 com.apple.CoreText 2.0.1 (???) <07494945ad1e3f5395599f42748457cc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90df1000 - 0x90e70ff5 com.apple.SearchKit 1.2.0 (1.2.0) <277b460da86bc222785159fe77e2e2ed> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x90e71000 - 0x90e7bfeb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x90f0b000 - 0x912c9fea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x91301000 - 0x91afefef com.apple.AppKit 6.5.2 (949.26) <bc4593edd8a224409fb6953a354505a0> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x91aff000 - 0x91f0ffef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x91f10000 - 0x91f3afff com.apple.CoreMediaPrivate 1.4 (1.4) <59630ee9096ecf2ca1e518da2f46c68d> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x92019000 - 0x9202dff3 com.apple.ImageCapture 4.0 (5.0.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x9202e000 - 0x920f5ff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x920f6000 - 0x920fefff com.apple.DiskArbitration 2.2.1 (2.2.1) <75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x93087000 - 0x9311aff3 com.apple.ApplicationServices.ATS 3.2 (???) <cdf31bd0ac7de54a35ee2d27cf86b6be> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9311b000 - 0x931a7ff7 com.apple.LaunchServices 286.5 (286.5) <33c3ae54abb276b61a99d4c764d883e2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93327000 - 0x93361fff com.apple.coreui 1.1 (61) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x93362000 - 0x93371ffe com.apple.DSObjCWrappers.Framework 1.2.1 (1.2.1) <eac1c7b7c07ed3148c85934b6f656308> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x9338f000 - 0x933c0ffb com.apple.quartzfilters 1.5.0 (1.5.0) <22581f8fe9dd2cb261f97a897407ec3e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x933c1000 - 0x93433fff com.apple.PDFKit 2.1 (2.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x93441000 - 0x93578feb com.apple.imageKit 1.0.1 (1.0) <4cb353ae2d3b141afc3d82b557bde878> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x9357d000 - 0x936affef com.apple.CoreFoundation 6.5.1 (476.10) <d5bed2688a5eea11a6dc3a3c5c17030e> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x936b0000 - 0x9372cfeb com.apple.audio.CoreAudio 3.1.0 (3.1) <70bb7c657061631491029a61babe0b26> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9372d000 - 0x9373dffc com.apple.LangAnalysis 1.6.4 (1.6.4) <cbeb17ab39f28351fe2ab5b82bf465bc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9373e000 - 0x93a46fff com.apple.HIToolbox 1.5.2 (???) <7449d6f2da33ded6936243a92e307459> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93a47000 - 0x93a4dfff com.apple.print.framework.Print 218.0.2 (220.1) <8bf7ef71216376d12fcd5ec17e43742c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93a4e000 - 0x93a4eff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x93a4f000 - 0x93a5ffff com.apple.speech.synthesis.framework 3.6.59 (3.6.59) <4ffef145fad3d4d787e0c33eab26b336> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x93a74000 - 0x93a74ffa com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93a75000 - 0x93d89fe2 com.apple.QuickTime 7.4.1 (14) <1a4838d29e0804a2a102f03c053600f0> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x93d8a000 - 0x93db9fe3 com.apple.AE 402.2 (402.2) <e01596187e91af5d48653920017b8c8e> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x93dba000 - 0x93df1fff com.apple.SystemConfiguration 1.9.1 (1.9.1) <8a76e429301afe4eba1330bfeaabd9f2> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x93e10000 - 0x93fcbff3 com.apple.QuartzComposer 2.1 (106.3) <ed79ff3644e8883905ba3ba681742476> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x93fcc000 - 0x93ff7fe7 libauto.dylib ??? (???) <42d8422dc23a18071869fdf7b5d8fab5> /usr/lib/libauto.dylib
0x93ff8000 - 0x93ffdffb com.apple.DisplayServicesFW 2.0 (2.0) <8953865f53e940007a4e4ac5390d3c95> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x94003000 - 0x94008fff com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x94009000 - 0x94083ff8 com.apple.print.framework.PrintCore 5.5.2 (245.1) <3c9de512e95fbd838694ee5008d56a28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x943b5000 - 0x943d2ff7 com.apple.QuickLookFramework 1.1 (170.2) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x943d3000 - 0x9447afeb com.apple.QD 3.11.52 (???) <c72bd7bd2ce12694c3640a731d1ad878> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9447b000 - 0x944bcfe7 libRIP.A.dylib ??? (???) <9d42e83d860433f9126c4871d1fe0ce8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x944bd000 - 0x94b56fff com.apple.CoreGraphics 1.351.21 (???) <6c93fd21149f389129fe47fa6ef71880> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x94b57000 - 0x94b5efe9 libgcc_s.1.dylib ??? (???) <f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x94b5f000 - 0x94b7affb libPng.dylib ??? (???) <b6abcac36ec7654ff3e1cfa786b0117b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94bc0000 - 0x94c4cffb com.apple.QTKit 7.4.1 (14) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x94c4d000 - 0x94caaffb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x94cc5000 - 0x94cdbfe7 com.apple.CoreVideo 1.5.0 (1.5.0) <7e010557527a0e6d49147c297d16850a> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94cdc000 - 0x94d04ff7 com.apple.shortcut 1 (1.0) <057783867138902b52bc0941fedb74d1> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x94d3a000 - 0x94d59ffa libJPEG.dylib ??? (???) <0cfb80109d624beb9ceb3c43b6c5ec10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x94d5a000 - 0x94d5cfff com.apple.securityhi 3.0 (30817) <2b2854123fed609d1820d2779e2e0963> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x94d5d000 - 0x94d7bfff libresolv.9.dylib ??? (???) <0629b6dcd71f4aac6a891cbe26253e85> /usr/lib/libresolv.9.dylib
0x94d7c000 - 0x94e03ff7 libsqlite3.0.dylib ??? (???) <6978bbcca4277d6ae9f042beff643f7d> /usr/lib/libsqlite3.0.dylib
0x94e82000 - 0x94e82ffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94e83000 - 0x94fa7fe3 com.apple.audio.toolbox.AudioToolbox 1.5.1 (1.5.1) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x94fa8000 - 0x94fa8ffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x94fa9000 - 0x94febfef com.apple.NavigationServices 3.5.1 (161) <cc6bd78eabf1e2e7166914e9f12f5850> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9554a000 - 0x9558ffef com.apple.Metadata 10.5.2 (398.7) <73a6424c06effc474e699cde6883de99> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x95590000 - 0x955dffff com.apple.QuickLookUIFramework 1.1 (170.2) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x955e0000 - 0x9569afe3 com.apple.CoreServices.OSServices 224.4 (224.4) <ff5007ab220908ac54b6c661e447d593> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9577b000 - 0x9577bffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x957ba000 - 0x9580aff7 com.apple.HIServices 1.7.0 (???) <f7e78891a6d08265c83dca8e378be1ea> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9580b000 - 0x9580cffc libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x9580d000 - 0x9584cfef libTIFF.dylib ??? (???) <6d0f80e9d4d81f3f64c876aca005bd53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9584d000 - 0x95992ff7 com.apple.ImageIO.framework 2.0.1 (2.0.1) <68ba11e689a9ca30f8310935cd1e02d6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x959e2000 - 0x959f8fff com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x959f9000 - 0x95a02fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <d3180f9edbd9a5e6f283d6156aa3c602> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x95a03000 - 0x95a03ffb com.apple.installserver.framework 1.0 ( /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x95add000 - 0x95ae8ff9 com.apple.helpdata 1.0 (14) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x95ae9000 - 0x95b01fff com.apple.openscripting 1.2.6 (???) <b8e553df643f2aec68fa968b3b459b2b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x95b02000 - 0x95b5eff7 com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x95b5f000 - 0x95b63fff libGIF.dylib ??? (???) <d4234e6f5e5f530bdafb969157f1f17b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x95b64000 - 0x95b6bff7 libCGATS.A.dylib ??? (???) <9b29a5500efe01cc3adea67bbc42568e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x95d56000 - 0x95d56ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x95d57000 - 0x95d5bfff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x95d5c000 - 0x95e3dff7 libxml2.2.dylib ??? (???) <450ec38b57fb46013847cce851001a2f> /usr/lib/libxml2.2.dylib
0x95e3e000 - 0x960b8fe7 com.apple.Foundation 6.5.4 (677.15) <6216196287f98a65ddb654d04d773e7b> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x960e9000 - 0x96126fff com.apple.CoreMediaIOServicesPrivate 1.4 (1.4) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x96127000 - 0x961d0fff com.apple.JavaScriptCore 5523.10.3 (5523.10.3) <9e6719a7a0740f5c224099a7b853e45b> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x961d1000 - 0x9624efef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9624f000 - 0x9624ffff com.apple.Carbon 136 (136) <98a5e3bc0c4fa44bbb09713bb88707fe> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x962bd000 - 0x96346fe3 com.apple.DesktopServices 1.4.5 (1.4.5) <8b264cd6abbbd750928c637e1247269d> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x96347000 - 0x96347ffe com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <a2b462be6c51187eddf7d097ef0e0a04> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x968d1000 - 0x96a09ff7 libicucore.A.dylib ??? (???) <afcea652ff2ec36885b2c81c57d06d4c> /usr/lib/libicucore.A.dylib
0x96a63000 - 0x96af6fff com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x96af7000 - 0x96ba7fff edu.mit.Kerberos 6.0.12 (6.0.12) <9e98dfb4cde8b0510fdd972dc9fa1dc9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x96ba8000 - 0x96ba8ff8 com.apple.Cocoa 6.5 (???) <e064f94d969ce25cb7de3cfb980c3249> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x96ba9000 - 0x96bb0ffe libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x96bb1000 - 0x96c28fe3 com.apple.CFNetwork 221.5 (221.5) <5474cdd7d2a8b2e8059de249c702df9e> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x96c9c000 - 0x96d81ff3 com.apple.CoreData 100.1 (186) <8e28162ef2288692615b52acc01f8b54> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x96d82000 - 0x96d84ff5 libRadiance.dylib ??? (???) <20eadb285da83df96c795c2c5fa20590> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x96d85000 - 0x96f50ff7 com.apple.security 5.0.2 (33001) <0788969ffe7961153219be10786da436> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x96f51000 - 0x96f5cfe7 libCSync.A.dylib ??? (???) <df82fc093e498a9eb5490761cb292218> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0xba900000 - 0xba916fff libJapaneseConverter.dylib ??? (???) <7b0248c392848338f5d6ed093313eeef> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe2 libKoreanConverter.dylib ??? (???) <51586b8d9ef39123fbe6918f12d8285f> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
_________________
OS10.5 Leopard
MacPro 3.0 GHz 8 Core 7GB
G5 2.5 GHz Quad 4.5 GB
ArchiCAD 11 Modo 301
