- Fri Feb 01, 2008 9:32 am
#260035
Hi.
I've accidentally built the Windows version of the new 1.6.6 plug-in with a newer version of Microsoft Visual Studio. This means that you might need to install one or both of the following Microsoft packages to be able to use the plug-in.
If you're using 32-bit Windows, install this: http://www.microsoft.com/downloads/deta ... laylang=en
If you're using 64-bit Windows, install this as well (that is, you need both packages): http://www.microsoft.com/downloads/deta ... laylang=en
I'm sorry for the inconvenience.
