By adri
#258848
Hi
I'm getting the message 'render failed' when I try to render out a scene from C4D and also when the same scene is imported to MXST.
It doesn't give any more information than that.
Anyone?
TIA
Adri
By Rochr
#258873
Check to see if you have any deformer objects applied. Maxwell dont work very well with those, and i´ve gotten all sorts of error messages when using them. One is the "render failed" one.
Sometimes it can also help to delete the existing .mxs-file and generate a new one.
By RichG
#259003
Also check your paths to textures and scene files. I have an unhealthy habit of using odd characters to force a folder to the bottom of the list but I once referred to a texture in such a folder and Maxwell would just fail without giving a reason. Avoid any kind of unusual characters in your paths.
