By mojo
#255387
when rendering out form formZ with option skydome and "use sun" box checked, the rendering gets more or less black areas...
By mojo
#255388
hm?
after a new attempt, nothing is black anymore, but the rendering has no direct sunlight anymore, though "use sun" is checked...
what is going on here ?
By mojo
#255391
when opening the mxs ecene in studio, the environment parameters are no the same i used in my plugin
By juan
#255397
mojo wrote:when opening the mxs ecene in studio, the environment parameters are no the same i used in my plugin
If you have choosen sky dome, the physical sky parameters won't be properly passed (they won't be used in the render anyway). is it what you mean, or the sky dome parameters are not properly passed as well?
Juan
By mojo
#255403
juan, you are right, i chose skydome.
when creating an mxs out of formz with pysikal sky, the settings are the same in studio. thanks.
but what do i wrong with skydome+ "use sun" using the plugIn ??
By mojo
#255405
juan,
my attention, to use this option is to minimize the rendertime in an interior rendering. could you tell me if it is really faster ?
By juan
#255793
mojo wrote:juan,
Actually there won't be much difference.. in an interior rendering there are other factors that are much more important. If you post here an sketch of the scene you are trying to render (if this is confidential you can just write a description) I could give you some tips :)
Juan
