By monochrome
#249712
I should have tried that....
Is it possible to have the rendering ignore the clipped geometry? For
example, if you're cutting through a 6-walled box, the rendering will be black.
By mgroeteke
#249720
monochrome wrote:I should have tried that....
not sure if you can do that in FZ, best is to try ;)
markus
If you clip the geometry you will still get the same lighting as if that geometry was still there, so it's not possible now.
By monochrome
#249759
A z-clip plane that is independent of camera and clips the geometry completely would be a boon for architectural/engineering section renderings.
Is that even a possibility with the way z-clip works in Maxwell?
