By J Bradshaw
#242699
Hi all - found a small bug in 1.5.1 using the Material Wizard for wood,
after choosing the image and bump maps etc., and back into the editor
dialog box both bump maps in the surface properties are unchecked along
with the roughness map in the reflections surface properties so one has too
manually check them. If I remember correctly this was not the case in 1.5.
Cheers, J Bradshaw
