Maya plugin Version 1.5.5 for Mac
- The glass wizard has been updated to match MXED 1.5.
- The MXI path is now always set to prevent MXCL from writing MXI files everywhere.
- New projects could not be created because the Maxwell exporter was called "Maxwell Scene".
- Reddish material preview problem solved.
- Material browser problem solved.
The space has been removed, so now it is "MaxwellScene". Please note that if you have exported a scene and saved it, when trying to export it again with this plug-in you may get an error about "MaxwellScene" not being recognized. If this happens, select any other format in the "Files of type" dropdown, then select "MaxwellScene" again (without exporting in between).
new Maxwell Cloud Portal
We’re excited to introduce the new Maxwell C[…]
