- Wed Jun 20, 2007 2:54 pm
#233754
This occurred to me a couple times while setting to high values the frame width while the maintain proportion checkbox is off. In these cases the perspective is completely deformed, as if i was using a 1mm wideangle, and there is no way to set it correctly even by resetting original values. Perspective view is altered also in these cases and every single new camera i create. To make it work again i have to delete the camera and then create a new one. Do you confirm this?
Running 1.5.0.2 on a Macpro dual dualcore 2,66 Ghz equipped with 5 GB RAM.
EDIT: Talking about cameras, in the same scene where i got this problem last time, i just realized that the camera is really confused. The focal length is altered since i am getting a 80mm or so-like shot while having set it to 24mm, and even the exposure times behave strangely: for having the same exposure on the image i have to set speed to 1/50 while before the optimal setting was 1/500....
- By Matteo Villa
