By Daniel Hruby
#232125
Pavol,
Can you add an opion in the plug-in for either transfer of internal Lattitude and Longitude to the plug in as well as time of day settings? At least they should all default to the settings made within ArchiCAD.
And/or
Could you add the option to choose a KML file to be used to define location like you can in Studio? It keeps me from having to A) remember it or B) look it up in the 3D Projetcion Settings: Sun settings and C) do the math to convert minute second to decimal degrees.
Thanks!
By pelias
#232296
The problem with location/date/time settings from ArchiCAD is that these are not available for rendering add-ons. I am working on a workaround to make it available but that's rather tricky.
KML support in plugin certainly shouldn't be a problem - I am putting that on the ToDo list.
Pavol
