By zoppo
#228009
i started a coop rendering on 3 machines:
1 - server and manager
2 - server
3 - server
nr2 crashed completely but nr1 showed no reaction at all.
nr2 is still in the render farm list.
job queue shows:
1 - waiting for others
2 - rendering (!)
3 - receiving mxi
and that's it ... no mxi has been written ... all lost :x
Make sure,
- You installed same versions on each node.
- There are no firewall restrictions.
- There are available TEMP harddisk space on each node.
- There's no other application (like resident antivirus tasks) blocking access to coop files.
Also, do you encounter same problem after you close and then restart all the servers and the manager?
By zoppo
#228124
tom wrote:Make sure,
- fresh installed 1.5
- i don't think so. mxcl has full access and server rights granted. and they are all in the render farm window.
- lots of ...
- i got one av running (on the main pc nr1). but i don't think it blocks anything.
about restart: naturally i restarted pc2 that had crashed. but nr1 did not react at all - network status in mw stayed the same. so i had to restart nr1's manager and server. still no luck, as the manager only found the server running on the same machine.
so i restarted server on all three pcs and then started manager on nr2. they have been rendering now for 4 hours :D
but the important question is: what is supposed to happen when one of the clients crashes while rendering? and what happens when i decide to stop one of them while rendering in coop?
By deadalvs
#228125
if You stop just one slave, it will wait for new work, and the job is progressing.
where did You create the .mxs ? studio or host app?
be VERY sure that every single texture has a path in unc form and also the output paths are correct in this form:
//computername/folder/texture.pic
don't use mapped drive names like T:\ !
By zoppo
#228129
deadalvs wrote:if You stop just one slave, it will wait for new work, and the job is progressing.
i created it in studio, but it was a resaved 1.1 scene.
every single texture was there as i used a pack&go directory.
BUT ... i used it as a mapped drive ... :(
AND ... while typing i stopped my coop render to test this - and it worked, the mxi was written on the mapped drive :wink:
BUT 2 - for a test i stopped one of the servers in the manager and then closed it - and its contribution was lost i think. is this behaviour wanted??
By deadalvs
#228131
zoppo wrote:is this behaviour wanted??
:roll:
hmm. i think i did also tests with mapped drives. the manager found them, the pc that the textures acually are on, but the third computer didn't start.
i also found my computers computing «something» but producing nothing. that was strange...
