By mtripoli
#222440
After sometime being away from using MXR and SW, I tried again.
After I installed the plugin, none of the textures show up in the texture window, and most of the icons are missing the graphic. I've just updated to SP3.1 - are there any issues here?
I *think* I've followed the instructions correctly to install - but I've been wrong before...
One other thing: I can hit render and it will - diffuse surfaces applied to both objects. I do not have any emitters in the scene; I was using sunlight. When I turn off sunlight, it still renders an image. The object (a simple sphere) can still be seen. I would have expected that the scene is black! What am I mis-understanding?
Thank you!
