#200658
Maxwell Render for Cinema4D Plugin Software Issues:
1 - Please ensure that your problem is not already known
because it may have already been solved. Check this sticky for posting
of new bugs or issues.
2 - Please verify you are using the current plugin and render
engine
version for your platform.
3 - Any registered user of the Cinema4D plugin on the
Maxwell Render forum can submit a issue report by posting a new
thread with the following information as a suggestion:
-Operating System and Version
-System hardware
-Description of situation in which the problem occurred
-Can the problem be reproduced in a certain way?
-Provide Rendered Images to illustrate problem if possible
-Provide archived MXS file and any bitmaps if possible
-Report one unique issue per thread
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=4126
4 - Please allow Next Limit to research and evaluate your issue
report in a timely manner.
5 - Please understand that your report is in the process of
evaluation, no further action is required of you.
6 - Your efforts to help identify problems in the software are
appreciated. A solution to your inquiry is on its way!
Current Issue Reports:
Current Plugin Version: Cinemaxwell 1.1k
PC.......Version: Updated Releases: 12/04/06
MacOS Version: Updated Releases: 12/04/06
Other issues solved:
[Critical] Issues
None to Report
[Grave] Issues
None to Report
Work Around: Use Maxwell Studio to setup HDRI/MXI feature
[Pending] Issues
None to report.
[Normal] Issues
None to report.
User Suggestions:
01:
Relative paths for material texture links using the Custom MXM material tag in Cinemaxwell.
02:
Export of additional cameras into the MXS file. At the moment, you have to export additional MXS files for every additional additonal camera view besides the one current one selected and then merge them all into one main MXS file to have different camera views in one single MXS file.
03:
Export of C4D Scene to MXS: Convert Cinema 4D hierarchy to a group hierarchy in Maxwell Render Studio.
Severity Levels Explanation:
CXX - Critical-----[Crash][Breaks Unrelated Software][Loss of Data]
GXX - Grave------[Incorrect functionality][interface logic][Feature Mostly Unusable]
PXX - Pending---[Known/In progress Fix]
NXX - Normal----[New][Default Severity]
XX - Issue/Bug Assigned Number
Thanks to Thomas An. (Rhinoll Bug List) and Kabe for contributions to the
organization of this report.
Manual Notes:
Instanced Objects are not supported yet. These will need to be converted into editable objects.
Previous Report
