- Sat Oct 14, 2006 2:28 pm
#189263
I'll try to explain it at my best.
Most of the times I like to work with the plugin just to test the scene and the geometry while working: once finished modeling I usually use studio for the final setup, fine tuning and to check the material creation (basically to check and avoid wrong material assignment, polygon without materials etc).
I create and assign many materials during this process, mostly via plugin.
It would be nice if the materials changes done in studio are automatically saved overwriting the original mxm file, without the need to export the material.
This way, if you have to get back to the scene for some geometry/modeling change, you don't have to update or recreate the same changes made in studio to the mxm, thus skipping the need of a further step in studio only to reload the geometry.
I hope it does make sense.
Do you want me to sit in a corner and rust or just fall apart where I'm standing? | Marvin da paranoid android
- By jack marvia
- By Mark Bell
