#183904
channels...
would make material handling quite faster...
to me would be grater if one could just make instance of the tiling settings e not of the textures... so if un have a certin diffuse map e the corrispondent bump map, which must have the same scale, one just modify the values on the bump map
did you tried luxCore?
