- Fri Aug 04, 2006 7:12 pm
#175629
Dear user,
I am tryng to use a PC like a slave on run all
mxcl -server -p:low
mxcl -d -p:low
mxcl -manager -p:low
the setup works fine
On another pc I run formz and setup the plug-in window on command line with the -server option.
It appen that the manager on pc slave don't start the render because it says
No active camera found in mxs
the same as if I manual add job with the manager.
But if I render directly on the same PC as formz, it render right without any error.
Is there a way to tag a camera in formz where it will be saved the info in the mxs?
thanks for suggestion
mxcl -server -p:low
mxcl -d -p:low
- By jack marvia
- By Mark Bell
